I am using Win 10 and Chrome.
The fitbit.com sleep tool display changed yesterday.
Not in a good way.
Before yesterday, I would go to the sleep tracking page every day and correct the start time for falling asleep. The fitbit surge rarely detects my sleep start time correctly because I wake up a lot.
The user interface of the sleep tool used to open to show a chart of "last nights sleep".
It now opens to show last week.
The big problem is that I can't edit & save a new sleep start time.
How do I do this?
I can edit the sleep start now, but the graphic display does not change and I can't save the corrected start time.
Help!!!
You can edit it.
If you pull the record up it will bring up a new page to edit
Hope that helps!
Wendy | CA | Moto G6 Android
You can edit it.
Hope that helps!
WndyB,
Thanks.
I tried that before, but was confused about the "Edit" button.
The way it works is to change the start time and then click the Edit button. I was doing it in the opposite order.
The "Edit" button is really a "Save" button.
Glad you got it figured out!
