@anandv @ericrude It is nice to have you both in the Fitbit community. Thanks @anandv that is correct, that is one of the easiest way to check the Surge battery. However @ericrude, if you use your computer, you can check this by clicking on the gear too (the gear is located at the top right corner of your dashboard):smileyhappy:.
Hope this information helps! ![]()
how come the Surge is using alot of battery juice at the middle of the day
@CarlosFitbit wrote:@anandv @ericrude It is nice to have you both in the Fitbit community. Thanks @anandv that is correct, that is one of the easiest way to check the Surge battery. However @ericrude, if you use your computer, you can check this by clicking on the gear too (the gear is located at the top right corner of your dashboard):smileyhappy:.
