10-10-2017 10:12
10-10-2017 10:12
Hi everyone. I have just gone from a Fitbit blaze to the surge (seems more appropriate for running with its built in gps!).
In prep for a run tomorrow I was curious to know, once my Fitbit is connected with strava ...which it is... once I have completed a run will it automatically sync to strava, or will I have to do it myself like with the blaze?
thanks guys!
Best Answer10-19-2017 16:46
10-19-2017 16:46
It's great to have you here @Elenatizzard! So cool to hear that you're using a Fitbit Surge now. 🙂
Strava will work directly with Fitbit app (online Dashboard) not exactly with your Fitbit tracker. This will work just as it did when you were using your Blaze. You can learn more about it by checking this third-party post.
Hope this clarifies any doubt! ![]()
