06-13-2018
19:44
06:04
YojanaFitbit
06-13-2018
19:44
06:04
YojanaFitbit
My display has started to miss pixels in it. I have reset the fitbit with some improvement. But us there something else I should do apart from buying a new one which is out of the question.
Moderator edit: Updated subject for clarity.
06-21-2018 13:50
06-21-2018 13:50
Thanks for getting back @Loveym. I'll be more than glad to explain what I meant when I said reconnect your Fitbit.
Basically are these steps below (you can use your phone if you have one):
Hope this helps and welcome again! ![]()
06-14-2018 06:02
06-14-2018 06:02
Nice to see that you're digging into the Forums @Loveym, let me give you a warm welcome to our Community. ![]()
You're in the right place to share your inquiry, thanks for trying to restart your Fitbit; that's the first step when having hardware issue. Why don't you try to reconnect it with your device, this might work. If not let me know so I can help you with the next step.
Let me know the outcome!
06-14-2018
14:00
13:19
YojanaFitbit
06-14-2018
14:00
13:19
YojanaFitbit
Not quite sure what is meant by reconnect my surge! I was connected to PC yesterday.
Display is still the same
06-21-2018 13:50
06-21-2018 13:50
10-16-2018 22:52
10-16-2018 22:52
Hey, thanks for suggesting the solution. I am not sure if my fitbit is missing pixels but it shows gibberish display on the screen. When scrolled for anything it start fluctuating randomly. It is quite difficult to manoeuvre inside the screen. I have restarted the device, uninstalled the app, installed it again, re-synched my device onto the app again, but to no avail of anything working, Could you help with something apart from this.
10-17-2018
03:40
11:13
YojanaFitbit
10-17-2018
03:40
11:13
YojanaFitbit
Nothing has made any difference to my display. I am still wearing it but
using the app to record my exercises.
Margaret L
Moderator edit: Removed personal information.
10-23-2018 11:36
10-23-2018 11:36
Nice to see you here @abhushan86! Your feedback is really appreciated. @Loveym thanks for getting back.
@Loveym Thanks for details on your post and for the attempts to solve the issues with your Surge. I've requested a case for you, our team will be contacting you via email shortly. Our team will be reaching out shortly.
Let me know if you have questions about it
