07-22-2017 20:32
07-22-2017 20:32
My Surge got into the shower with me by mistake 😞 Now it pretty much shut down.
I cannot charge it.
I cannot swipe left or right.
I cannot click any of the side buttons.
H E L P please.
Thanks
07-22-2017 20:34
07-22-2017 20:34
I am really sorry.
Try putting it in to rice for 48 hours.
But its probably toast and you will need to get a new one. Sorry.
Wendy | CA | Moto G6 Android
07-22-2017 20:35
07-22-2017 20:35
Also warranty is here and getting wet is not covered
https://www.fitbit.com/legal/returns-and-warranty
Ask support what they can do for you
07-23-2017 03:45
07-23-2017 03:45
07-23-2017 13:32 - edited 03-22-2018 11:58
When Surge was first released it had a 50 meter depth rating, but this is tested by increasing the pressure very slowly. You cn find a youtube video of this test.
The force of diving into a pool or the flow of water out of a shower head can easily exceed this pressure, and would be a good reason not to swim with the tracker. It should however be safe with the accidental drop in water, or washing of the hands.
07-23-2017 14:50
07-23-2017 14:50
07-23-2017 22:15
07-23-2017 22:15
They already have a swimproof model, the Flex 2. As for tue Future only Fi5bit knows, and if they told us, well.. you know what follows.this line..
07-24-2017 06:42
07-24-2017 06:42
Thank you! My got a little wet and I thought it was toast! So, I reset it like you mentioned, and it works!! 👋🏻👋🏻👋🏻
Thanks!
Dana
07-24-2017 10:43
07-24-2017 10:43
I'm sorry, but there is no way a surge should be ruined by a simple shower. Maybe if your band is falling apart around the watch casing, but if you have 0 damage, this just should not be an issue. I don't shower with mine (I only stopped because the soap was leaving a white build up around the band), but I frequently run/walk in very heavy downpours and although I can't swipe the screen when the display is wet, it has never leaked into the internals. If it's under warranty I would get a replacement. Emujo
07-24-2017 13:13
07-24-2017 13:13
07-24-2017
17:37
08:45
YojanaFitbit
07-24-2017
17:37
08:45
YojanaFitbit
And you can't sweat while wearing it either or the screen fogs up. Duuhhhh.... Defeats the purpose of having it while working out. But they will offer to sell you a replacement for 25% off!!!
Moderator edit: Word Choice
07-27-2017 09:13
07-27-2017 09:13
My Surge did the same thing last week, I did not submerge the Surge, I just forgot to take it off before I got in the shower. It was a few days before I started the bowl of rice to dry it out. The water/fog is gone after a couple days in rice the touch screen is now working again but the screen (under the glass) looks like it is shattered underneath. Not from physical damage but from the fog? Will the screen go back to normal.... will the shatter disappear in a while? has anyone had the same problem? I am out of the warranty period. I really enjoy this watch but I'm disappointed with the quality, i thought a sports watch would be water resistant (kinda surprised seeing FITBITS reputation), I guess I will have to change Co/brands the next time . Any advice would be appreciated.
07-27-2017 10:14
07-27-2017 10:14
07-29-2017 08:51
07-29-2017 08:51
Hi @Bnmn, @GreenMTFIT, @clarkfp and @Runmomrun123! So glad to see you around! Thanks for the help @Emujo and @Rich_Laue. ![]()
I appreciate the time you took to place your feedback here in the Forums! Our team is always trying to get the best option for you using your Fitbit warranty so in case that you haven't contact our Support Team, please let me know so I can arrange they can contact you directly!
Again thanks for your feedback, Fitbit takes this in consideration to improve product and services!
03-21-2018 05:30
03-21-2018 05:30
My Surge has blanked out after getting wet in the shower. Anything we can do about it regarding a new one?
Still trying the rice trick.
Will
03-23-2018 05:58 - edited 03-23-2018 06:00
Nice to see that you're digging into the Forums @Tendonsnap, let me give you a warm Welcome to our Community. ![]()
It's good to know that you're trying to help your little buddy using the rice trick, it usually takes around 24 or 48 hours to dry out; but I've already requested to our support team to create a case on your behalf so they can follow up with you. You should soon receive an email from customer support at the email you used to register with the Community Forums.
Please keep me posted! ![]()
08-06-2018 06:48
08-06-2018 06:48
Hello. My surge got wet and the screen is displaying nothing. There is only this map like water mark inside my surge. Please help..
08-17-2018 13:41
08-17-2018 13:41
Ouch, I'm sorry that your tracker got wet and it seems not to be working well. ![]()
I would say, to make sure that all the moisture comes out of the tracker, the univesal advise of putting your tracker in a bowl full of rice should help. Something else to try would be to put it in a jar or a ziploc bag with two or three packets of silica gel pellets (the ones that come in the shoe boxes). Both, rice and silica pellets absorb moisture and will help take out any that is still inside your tracker. Be sure to leave your Blaze there for about 24-48 hrs. and then take it out and see how it works.
Let me know how it goes and welcome to the Community Forums @Rhaiven! ![]()
