Surge is working only connected with USB cable
ANSWERED
My Fitbit Surge turned off automatically and i could not switch it on untill i connected it to USB port. Battery is full but after i disconnected Surge from USB port it died right away. Any advices on this issue?
2 BEST ANSWERS
Accepted Solutions
Hey there @autr30! I hope you're doing great!
Let me help you out, double check that you're charging it the way it says on this article, if the issue persists I agree with @SunsetRunner and contact the Support Team so they can review your device history and tell you the options.
Let me know how it goes!
Magin | Community Moderator, Fitbit
If you find something helpful, give it a vote and don't forget to mark it as an Accepted Solution!
5 REPLIES 5
Yeah, that's i think also.
@MaginB, @SunsetRunner was right, battery is dead. I'm waiting for replacement.
@autr30 It's great to hear that you're getting a replacement! Once you get it follow the instructions below in order to set it up:
  1. From the Fitbit app dashboard, tap the Account tab.
  2. Tap Set Up a Device.
  3. Choose your tracker and follow the onscreen instructions to continue.
Catch you later!
