08-05-2019 09:51
08-05-2019 09:51
My husband's Fitbit Surge has been synced, but it isn't working at all. I press the home button and touch the screen, but it is frozen. Does this Surge need a new battery? What else could be wrong with it. Thanks for your help. Loretta
Best Answer08-05-2019 11:10
08-05-2019 11:10
The batteries are not replaceable.
How old is it? Mine lasted 3 1/2 years
You can try these steps and see if it helps
Also See this thread for charging best practices. If you are not charging it correctly you could be damaging the battery
Wendy | CA | Moto G6 Android
