07-23-2016 05:08 - edited 07-23-2016 05:29
Tried to sync with Windows 10, Android devices, and restart the tracker, all failed.
What is wrong? It just happens....???
Best Answer07-23-2016 05:22
07-23-2016 05:22
Just tried Add as a new tracker from my Account on Fitbit Windows 10 mobile app. During the process, it say found the device and asked me to put in the 4 digit number displayed on the device but looking at tracker no number displayed, then the app falls in a dead loop
Best Answer07-23-2016 05:25 - edited 07-23-2016 05:33
Synced July 19, 2016 9:37PM
Version 34.5.14
Battery full
Best Answer07-27-2016 19:35 - edited 07-27-2016 19:42
Purchased an expensive Surge which lasts only 15 months, just a little bit time over its warranty. Now it refuses to sync, becomes useless 😞
For a while, I will not buy and recommend Fitbit products.
07-28-2016 02:29
07-28-2016 02:29
08-09-2016 05:17
08-09-2016 05:17
Hello @michaelye168 it's great to have you here! 🙂 Are you still experiencing issues with Syncing your Surge? If you are having issues my advise is to contact our support team, they can take a look at your tracker's back-end information and provide you personalized assistance.
Let me know how it goes! ![]()
It is health that is real wealth and not pieces of silver and gold! Share your story!
Best Answer08-28-2016 06:56 - edited 08-28-2016 06:57
Hello @michaelye168 @ChrisWaiting!
@michaelye168 If your tracker isn't syncing then please try restarting it by doing the following:
1.- Press and hold the Home and Select buttons (left and bottom right) on your Fitbit Surge for 10 to 15 seconds, until you see the screen flash or start to dim.
2.- Let go of the buttons.
3.- After your screen turns completely off, wait 10 seconds and press the Home button to turn your Surge back on.
After you can turn off the bluetooth on your phone (if you are using one to sync) for 30 seconds and then turn it back on. If you are using a computer restart it and try plugging your USB dongle on a different USB port.
@ChrisWaiting What type of issues is your tracker having? Have you contacted support already?
Best Answer08-28-2016 17:46
08-28-2016 17:46
11:47
10:26
08-29-2016
11:47
10:26
@StevePhelps Welcome to the Fitbit Community! I recommend following these syncing troubleshooting steps for iOS devices (check @SunsetRunner's steps on that post). That should certainly help with the syncing issues you are experiencing.
Try that out and let me know how it goes! ![]()
Best Answer08-29-2016 12:50
08-29-2016 12:50
Followed those steps. Nothing. Styll does not sync.
10:25
10:26
08-30-2016
10:25
10:26
@StevePhelps Thanks for trying the troubleshooting steps! In that case, I recommend reporting the problem to customer support. If it is defective, you may get a replacement as your tracker is less than a year old.
@Bwok16 Welcome to the Fitbit Community! Have you checked the newest trackers that were announced yesterday? Charge 2 and Flex 2 are the improved trackers with awesome new features. Make sure to check them out!
See you around! ![]()
