07-04-2016
09:43
17:01
MariamV
07-04-2016
09:43
17:01
MariamV
My Surge still tracks everything on its screen, as usual, but it won't connect to my phone or home computer anymore. So no update has came up on my dashboard over the last 5 days.
I always use only my phone, so at first I thought I needed to connect at home for some kind of update, but it doesn't connect at all.
Help anyone?
Moderator edit: format
Best Answer07-04-2016 11:18
07-04-2016 11:18
Best Answer07-04-2016 15:35 - edited 07-04-2016 15:36
Uninstall your computer application and download the latest application software and install it.
Run the application and it should sinc with your device. I had the same problem and did what I just described and it worked. ![]()
07-04-2016 17:22
07-04-2016 17:22
Best Answer07-04-2016 18:53
07-04-2016 18:53
Best Answer07-04-2016 18:59
07-04-2016 18:59
Not the iOS, it's the Fitbit app version 2.24.1 released on 30 June. Sorry for the confusion.
Best Answer07-05-2016 06:27
07-05-2016 06:27
Oh! Yes. Very possible because the dates match. However, as I said, it suddently began to work again so...
Best Answer08-10-2016 17:04
08-10-2016 17:04
@Thierrylarrivee welcome to the Community! Wow, it's good to read that your Surge began to sync again. Did you do something specifically? I'm sure I'm not the only one curious about it. 🙂
In case your tracker starts acting up again, I recommend restarting it by doing the following:
Good luck guys!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
10-21-2016 04:34
10-21-2016 04:34
Great suggestion for syncing the Surge. Worked perfectly!
11-13-2016 12:08
11-13-2016 12:08
A warm welcome to our new friend @Smurfinator! Thanks for letting me know that this suggestion worked perfectly for you!
Hope to see you around more often and happy stepping! ![]()
