Best AnswerI agree. I kept having the same problem. Seemed to help if I turned off bluetooth (as instructed) on my phone. It would work OK for a while then fail. Got a replacement dongle and that didn't help.
You would think in the tech age that needing to turn off blue tooth would be no longer need, but apparently not.
My solution is to use the phone app. When I want to force a sync I use the phone app to do it and it works all the time. It is a pain because using my desktop would have been simplier.
Im having the same issue . I do not have the ap . I just called support and was told to restart it . So far it worked but seeing this comment makes me worry . I live with two other FiBit users and I wonder if it is causing an issue with the bluetooth .
