07-30-2019 08:54
07-30-2019 08:54
Hi Fitbit elves, I have had my Surge for a while now and I have developed the "not swiping" issue that I have seen elsewhere. I have followed the remove, resynch advice and have followed it (but synching was never the issue). I don't understand why unlinking from my account would fix the swipe issue. I have changed the screen display, all is fine, except it won't swipe onto anything other than run / free run but that needs a left button press to start.
I see others still have the problem after allowing the device to run out of battery and it's not fixed the issue.
What are my options?
Thanks,
Phil
Best Answer07-30-2019 09:07
07-30-2019 09:07
From reading other threads (started in 2018) I can see that the answer seems to be "yup, it's stopped working, time to buy another device, here's a token discount on a new Fitbit". It'd be a shame if this is the result as I have enjoyed using Fitbit over the years and they've always been responsive to issues. Fingers crossed that there is a solution to this problem.
Best Answer07-31-2019 06:03
07-31-2019 06:03
Hi, you don’t really have any other option but replacing. As you said many people have this issue and basically it’s non fixable. Support will send you round in circles but with the same result- not working. Support will have you believe it can be fixed but the bottom line is they want you to purchase a new Fitbit. I hope I’m wrong in your case. Good luck
Best Answer08-03-2019 12:33
08-03-2019 12:33
Check that the screen is dry and clean and your finger is not wet.
Best Answer08-04-2019 02:39
08-04-2019 02:39
Best Answer08-08-2019 10:04
08-08-2019 10:04
Guys, I had the same issue and for the fun of it, i cycled power and full functionality was restored.
Best Answer08-09-2019 01:18
08-09-2019 01:18
Goof for you, what did you mean by cycle power . Thanks Rob
Best Answer08-09-2019 05:17
08-09-2019 05:17
