03-22-2016 18:51
03-22-2016 18:51
Hi,
My Surge stop syncing after 3/20 11:52pm. No matter how many times i sync it, the app still show that it lasted sync time is 3/20. When i click into the app, it will show the data today. However, once it past 12.00am, the previous date data will be gone. Please help
I have done nearly all the processes shown on this insturctions. I have used iOS and Windows 10 PC to sync. Not yet try the dongle.
Best Answer03-23-2016 07:46
03-23-2016 07:46
If you are sure Bluetooth (BT) is working (and assuming it worked on your computer before without the dongle) and you have re-booted your computer, I would try a couple of other things. Unpair the Surge from your computer's BT (in the computer's settings section). Delete the Surge from the Windows 10 app then re-install it. If that doesn't work, I would delete the app and re-install that. Let us know if either of those help.
Scott | Aviano Italy
Force, One, Charge, Charge HR, Surge - iOS
