Hi
The Surge doesn't has replaceable bands officially, though can be found on amazon.. to replace yourself..
* Replacing yourself can void warranty.
When having warranty on the Surge,
Best Answer@scott_j_collins Amazon sells an extension for the Surge band. This would keep any warranty intact.
That's very odd then as on the watch box it states XL straps are available online.
Best Answer@scott_j_collins The Surge has been discontinued and replaced by the Ionic. The Surge will probably be sold until none are left. I believe the Small is the only size left (online from Fitbit). Since Fitbit has always maintained the band is "not replaceable" it must be referring to buying a Surge with the Xtra large strap at the Online Store.
