05-05-2017 11:02
05-05-2017 11:02
Battery went dead earlier today. Plugged it in, and nothing happens at all! Tried different sockets and USB cables, but nothing is working.
05-05-2017 13:36
05-05-2017 13:36
Welcome to the forums!
Please clean the contacts
http://help.fitbit.com/articles/en_US/Help_article/My-tracker-s-battery-isn-t-charging/?q=not+chargi...
Then Do a Restart
http://help.fitbit.com/articles/en_US/Help_article/1186/?q=restart&l=en_US&fs=Search&pn=1
Also check out this thread for best charging practices. As you need to use a correct USB adapter
https://community.fitbit.com/t5/Charge/Fitbit-charge-battery-problems/m-p/1323307#M53291
If it doesn't help Contact Support
http://help.fitbit.com/?cu=1
Check out the discussions boards! A lot going on and I'm sure you have some contributions as well!
Hope to see you around!
Wendy | CA | Moto G6 Android
05-06-2017 07:18
05-06-2017 07:18
How you doing my friend @Welshy7? Welcome! ![]()
I noticed that @WendyB has offered a few suggestions to help resolve your issue. If so, I invite you to mark this post as the solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions.
If this didn't resolve your inquiry, I’ll be more than glad to lend you a hand with that!
Please keep me posted! ![]()
09-02-2017 10:13
09-02-2017 10:13
To get dead fitbit to charge.... plug in normal way. Press little side button 3 times within 8 seconds. You'll see green back light flash a bit and dead charging battery icon will appear on screen. You can check that it's charging by pressing button once... not hold, press... and charging battery icon will appear. Works for me. Good luck
09-05-2017 08:38
09-05-2017 08:38
We are glad to have you in the Forums @Gsj! Thanks for sharing your experience, it's really nice to see that you can use your knowledge to help other Fitbitters in distress! ![]()
In case that you haven't, please take a moment to visit our Discussions board where you will find other members sharing their experiences and tips. This is a really good way to stay motivated towards your goals. In case that you haven't do so, check it out! You might be interested in these topics: You know you're a Fitbit addict when...... or Looking for Fitbit Friends? Find some here!
Have a great day! ![]()
