09-05-2017 13:08
09-05-2017 13:08
I'm wondering that my surge no longer will sync is because Fitbit no longer sales the Surge. Is this happening to make be buy a new device.
Best Answer09-06-2017 00:09
09-06-2017 00:09
Syncing problems can happen from time to time for no apparent reason.
I would try restarting your phone and then restarting your fitbit using this procedure:
https://help.fitbit.com/articles/en_US/Help_article/1186/
Give this a few tries as it doesn't always work. If it still won't sync after that then there are some more ideas to try in this help file:
http://help.fitbit.com/articles/en_US/Help_article/1866
Best Answer09-06-2017 04:40
09-06-2017 04:40
I finally got the phone and fitbit to blue-tooth together. However it has not synced since August 27 and now the date and time are wrong.
I have tried your suggestions several times still with no luck. My phone is a Samsung Note 4 and it did a update if I remember correctly on August 26. Could there be a situation with fitbit no seeing the new version on the phone?
Best Answer09-06-2017 05:10
09-06-2017 05:10
Try deleting app and reinstall it mine worked
Best Answer09-06-2017 07:21
09-06-2017 07:21
Best Answer09-06-2017 07:24
09-06-2017 07:24
It could be. It may be best to contact customer support to see if they can see what's happening from the server side:
