08-10-2017 06:40
08-10-2017 06:40
My Surge won't connect, after my android updated on Tuesday night. It first started off by not syncing. So, I tried unpairing and pairing the device with Bluetooth. That didn't help. I tried restarting the fitbit, app and phone. I have now delete my Surge from the app, in order to connect it again. This turned out to be a bad idea because now it won't connect with the app at all. I just got this two months ago. What should I do?
08-10-2017 15:17
08-10-2017 15:17
Contact fitbit support it maybe your tracker is defective and needs replacing or they may be able to help you get it connected again. Good luck !
Best Answer08-10-2017 16:34
08-10-2017 16:34
It isn't just you, Android's update messed up a lot of us. On the Andoid forum they said it has been reported
08-10-2017 18:59
08-10-2017 18:59
Any idea what we do to fix it?
Best Answer08-10-2017 19:49
08-10-2017 19:49
I too have the same problem. My Surge has not synced since my update Tuesday morning.
08-11-2017 04:37
08-11-2017 04:37
I'm in the same boat, my surge won't sync for anything. A few weeks ago I had trouble with my charge 2 and now my surge. About time to leave FitBit and head to a new company!
08-11-2017 06:12
08-11-2017 06:12
Best Answer08-11-2017 06:12
08-11-2017 06:12
Best Answer08-12-2017 19:46
08-12-2017 19:46
I too have this same issue. I also did the same thing you did. I guess I'll have to set it up on my iPad till the Android issues are fixed. (Which works for now)
Take care and good luck folks.
Best Answer08-13-2017 09:53
08-13-2017 09:53
I have a Samsung with the same issue and chatted with a very helpful Fitbit support person. She told me, "the syncing issue is related to the update that Samsung released. Our engineers are currently investigating the changes that were included in the system update provided by Samsung so we can fix the syncing issue. But as of right now, there isn't an estimated time frame and I'd recommend syncing to a computer or another mobile device if you have one."
I asked how will we know when there is a fix to this problem. She replied, "We should receive an update from our engineers soon, but I recommend that you try syncing to your phone again in a week or so. We may post updates on our community board." She also provided a link to this thread: https://community.fitbit.com/t5/Android-App/Fitbit-trackers-not-syncing-after-Android-software-updat...
Best Answer08-13-2017 13:20
08-13-2017 13:20
08-13-2017 13:20
Best Answer08-14-2017 07:15
08-14-2017 07:15
Mine has done the same thing after the update. I also tried everything you did & now can not get it to connect back to the app. Bluetooth finds it & connects but not the app. Let me know if you figure something out
@aj27 wrote:My Surge won't connect, after my android updated on Tuesday night. It first started off by not syncing. So, I tried unpairing and pairing the device with Bluetooth. That didn't help. I tried restarting the fitbit, app and phone. I have now delete my Surge from the app, in order to connect it again. This turned out to be a bad idea because now it won't connect with the app at all. I just got this two months ago. What should I do?
08-14-2017 11:18
08-14-2017 11:18
So my surge won't connect to my phone or tablet. Both android based, so guessing it's an android issue and not just with Samsung as my phone is Sony and tablet Lenovo. It's a pain as I'm on an expedition in the Yukon and want to upload all my data. My surge isn't even a good watch at the moment as it is displaying the wrong time as well. Any idea on a fix for this as it's starting to wind me up
Best Answer08-14-2017 13:41
08-14-2017 13:41
