A warm welcome to the Community @HawaiiChipmunk. Could you please tell me what kind of error are you getting at the moment of syncing your tracker? In the meantime, I recommend following our Syncing Troubleshoot . After following these steps your tracker should sync without an inconvenience. Another thing that you could check is if your app is updated. You can follow @MarreFitbit's instructions in the How do I update the Fitbit app for Android post.
I hope this helps, let me know the outcome. ![]()
