02-03-2017 08:58
02-03-2017 08:58
My surge will not keep a charge anyone else having problems??
02-03-2017 09:06
02-03-2017 09:06
Hi, @RoxyLuv, it would be a good idea to give your Surge a restart to shut down any background activities that may be causing unusual battery drain.
As I am sure you are aware, GPS is very battery hungry, so while it is turned on your Surge battery will drain much more quickly than when it is off.
You also might want to have a look at these tips to prolong your battery life.
Welcome to the Community!
