04-20-2016
14:38
06:42
Mcore
04-20-2016
14:38
06:42
Mcore
I got my Fitbit Surge to sync on my computer by turning off bluetooth and the app. Then put in toggle. Go back to the app to sync; using the pink box. Sorted!
Moderator edit: Format
04-21-2016 06:43
04-21-2016 06:43
Awesome job @JamesAH! I'm happy to hear you were able to find the solution to your syncing issue with the Surge. Keep up the good work. ![]()
Any other comments or questions you might have, feel free to post back. It's great to have you here in the community!
