Hello,
I was wondering if there is a way to sync my Surge over the integrated bluetooth connection of my laptop? I am using a desktop PC at home with the dongle, but I would like to know if there is any way to use the sync software on my laptop without this dongle. I can succesfuly connect laptop and surge over bluetooth, but the sync software returns that I should plug in the dongle. Both my desktop and laptop run windows 8.1 and the laptop has bluetooth 4.0LE.
thanks,
Best AnswerWhen having Windows 10 it's possible to download a special Fitbit App from the Microsoft Windows Store, which allows to sync using bluetooth of the computer.
Hello @MDNS,
Welcome to the community!
The answer is yes and no.
Yes: If you install the Fitbit App, you will be able to sync your tracker with just Bluetooth 4.0.
No: Only the latest (Windows 10) version of the Fitbit App has this feature. That said, Windows 10 is a free upgrade from Windows 8.1.
I hope this helps.
Frank | Washington, USA
Fitbit One, Ionic, Charge 2, Alta HR, Blaze, Surge, Flex, Flex 2, Zip, Ultra, Flyer, Aria, Aria 2 - Windows 10, Windows Phone
Hello @MDNS,
I hope this helps.
good day!
just would like to ask, mine is fitbit surge. i already installed the fitbit app on my windows 10 pc and is already connected via bluetooth, but when i go back to the menu and synchronize it, it will go back to having the qoute plug in the dongle.. what shall i do next? pls help
