It's nice to see you around the Community @JFShelton, hope ou're doing great! ![]()
First of all, here are some tips for traveling with your Fitbit tracker:
If you're using the Fitbit app for iOS and traveling between time zones with your tracker, note the following information:
If you're using the Fitbit app for Android and traveling between time zones with your tracker, in the app settings find Set Automatically and turn off both the timezone and country options. If the timezone and country are set automatically, you may lose data or see your dashboard language change.
Did you make sure about the above?
