09-22-2016 17:31
09-22-2016 17:31
Best Answer09-23-2016 04:43
09-23-2016 04:43
A warm welcome to the Community @jeffmets. Have you checked your phone's settings? If you haven't, i recommend checking your phone's settings, keep in mind that your Surge will take the language that your have set on it.
I hope this helps, let me know the outcome. ![]()
Best Answer09-23-2016 04:47
09-23-2016 04:47
I feel you @jeffmets, I had this trouble last night.
However, this sounds very strange to me since the Japanese, Korean, and Chinese languages are not yet available on Surge. Are you seeing a different language on your App or tracker?
Changing the language on your mobile device will change the language in the Fitbit app.
Log into your fitbit.com dashboard. In the lower right corner of the footer you can choose your country. Your fitbit.com dashboard will automatically update to the primary language for the country selected.
To change the language on your tracker:
If the above didn't work, this is what worked for me last night:
Let me know the good news!
