The Surge records Sedentary time, Lightly, Fairly and very active time. Why is it that when I add these numbers plus Time in bed minutes it does not add up to 1440. There are 1440 minutes in a day. Provided I wear the watch the entire day all these categories of time should add up to exactly 1440 minutes. I had a day with 1543 minutes. How can this be possible? I can see rounding off time may mean 1440 plus or minus 5 minutes or so. I would like to know why many days are over 1440, many under 1440 but basically never exactly 1440 minutes.
Thanks for popping by the forums @karl2017! That sounds odd, where exactly are you looking the total amount of your minutes for the day? Because if I do the math, I would reach the same conclusion; but I want to be sure first that this is not a bug from the Dashboard. Would you mind including a graph, if it is possible.
I'll be waiting for your respose! ![]()
Hi @Andielyn, thanks for joining the conversion! ![]()
If you're having similar issues, please attach the picture with the information that you're getting, plus as many details as you might have; so I can follow up with you!
I'll be around! ![]()
