06-14-2017
05:52
15:16
MariamV
06-14-2017
05:52
15:16
MariamV
My screen has stopped working i can not swipe on it at all and I have only had it for a month.
Moderator edit: clarified subject
06-14-2017 05:58
06-14-2017 05:58
Probably got confused kimmy, you can reset your Surge and bring back its "swipe-ability" by holding the left and bottom right buttons until the screen begins to fade (count to 30 as you hold them in at the same time). Once the screen is blank press the left button to start it back up.
Better?
Thanks for checking!
WmChapman | TX
Ionic, Versa, Blaze, Surge, Charge 2, 3 SE, AltaHR, Flex2, Ace, Aria, iPhoneXR "Every fitbit counts"
Be sure to visit Fitbit help if more help is needed.
06-14-2017 05:58
06-14-2017 05:58
Better?
WmChapman | TX
06-14-2017 07:06
06-14-2017 07:06
Yes it worked thank you
12-19-2017 01:41
12-19-2017 01:41
I have the same problem. Factory resetted so many times. Unpaired paired my phone again. Did all the other troubleshooting methods but no luck:( First time had a problem with my Surge.
05-29-2018 09:39
05-29-2018 09:39
Hi.. i have my surge with the same problem, and your procedure doesn't work. There are another way to recover the touch screen?
05-31-2018 13:53 - edited 05-31-2018 14:00
Nice to see that you're digging into the Forums @Manuel_EC, let me give you a warm welcome to our Community.
Thanks for trying those suggestions, I wanted to let you know that I've got in touch with our support team and they will be getting in touch shortly.
Let me know if you have questions.
Best Answer06-02-2018 16:25
06-02-2018 16:25
I've tried and it has not solved the problem. Do you have any other solutions?
06-05-2018 14:14
06-05-2018 14:14
Hi @bobcat1966 how are you? Welcome to the Forums.
Thanks for following those steps, I already contacted out support team. They will be getting in touch with you shortly. Let me know if you have questions about it.
Have a good one.
