Warning on Surge
ANSWERED
What is the warning symbol that has started flashing on my Surge? It is a large triangle with exclamation point inside. I can't find a way to clear it, nor any explanation for it. Is this the new low activity warning?
1 BEST ANSWER
Accepted Solutions
I'm just surprised there was nothing about that symbol in the user guide
4 REPLIES 4
Hi, @SunsetRunner , no!  It means that the Surge is (or thinks it is) operating outside its environomental comfort zones -- most likely too hot -- but probably also too cold or too damp.  If you think you are using the Surge in a normal way and you are getting this warning, I would suggest a restart .  If it continues after a restart, repeat the procedure two or three times.  After that, if you are still getting this warning and you are using your Surge normally, it will be time to get in touch with Customer Support .
Good luck, and keep us posted.  Welcome to the Community!
Thanks. That is likely it, since I was sitting in the sun at soccer games.
Yes, the first I knew about it was when I accidentally wore it in the sauna...
