12-01-2016 14:45
12-01-2016 14:45
I am extremely upset with the warrantee loophole. I purchased my Fitbit Surge in August 2015 and in July 2016 the screen stopped working. I called the service hotline and was able to get a replacement device. However, less than three months later the band on the replacement Surge started stripping and bubbling at the faceplate. The band also started peeling away at screws. I called service to complain about the device and was told I would have to purchase a new Surge because the warrantee had expired from the original pair date of August 2015. I tried to explain to both the Supervisor and rep that the replacement item was defective. It is not a full three months since I received the device and even with normal wear and tear, the devices should not be in this condition and I should not be responsible for it but to no avail they insisted I purchase a new one at 25% off eventhough the replacement was defective. What else can I do? I really shouldn't have to pay for a new one if the replacement was defective!!
Best Answer12-01-2016 15:26
12-01-2016 15:26
Its not a loophole.
If you read any warranty for any item they state the same thing. It happened with my Washer. Its always from the day you buy the original
Wendy | CA | Moto G6 Android
Best Answer12-01-2016 15:43
12-01-2016 15:43
Best Answer12-01-2016 20:56
12-01-2016 20:56
My washer was defective after a 3 months as well it did not matter. It reverts back to the time you bought it. Check your other warranties.
Best Answer12-01-2016 22:36 - edited 12-01-2016 22:37
use cyanolit-gel to glue it.
i did one year ago and my Surge band is always good.
Best Answer12-02-2016 04:27
12-02-2016 04:27
