After a half year of syncing the fitbit surge with my Android it's no longer possible syncing..i tried reboot the smartphone, reboot the surge. Then I removed the surge from the app. The reconnect starts with "we found your Surge" then there come "it doesn't work" - check if other trackers are near the smartphone, check if surge is on.. try it again..
More than a day no chance to sync - very sad. The tips in the forums i tried and now is the question: Sell the Surge oder find a solution!
Thank you for help!
@Roldor Welcome to the Fitbit Community! It's great to have you here! It's odd that your Surge has stopped syncing suddenly. It seems that you have tried all the troubleshooting steps accordingly without success. In this case, I recommend contacting us Customer support so they can investigate further and get you back on track.
Keep me posted on the outcome and I'll be around my friend! ![]()
@honglong1976 Thanks for joining us my friend and sharing those great steps that helped you to get back on track. Hope the same results happen to @Roldor.
Let me know if you need more help! ![]()
@Roldor I'm sorry to hear that the issue could not get fixed. However, I'm glad that your case is being handled by our Support team and it's in good hands.
Hope to see you around in the Community my friend! ![]()
