01-28-2017 17:03
01-28-2017 17:03
after i had changed my timezone i clicked submit. Then i had to sync my fitbit.where is the icon to do that?
01-29-2017 01:19
01-29-2017 01:19
If you are using the app then closing the app and reopening it will cause a sync.
01-31-2017 09:42 - edited 01-31-2017 09:43
Welcome to our little Family @martyfo! Hope you're doing great. I'm guessing that you did those changes from a Computer in Fitbit.com Dashboard. Well, you have 2 views of the Dashboard, the computer view and the Fitbit App view. As @SteveH mentioned above you can synchronize your Fitbit Surge in the Fitbit App on your phone, by closing it and reopen it up. This will work in case that you have the option "All day Sync" enable in you Fitbit App.
If case that you don't have that option enable, you can force sync it by going to Fitbit App > Tap on Account > Surge > Sync Now.
If you want to sync with a computer follow the steps in this master post.
I'll be around! ![]()
