05-14-2018 01:55
05-14-2018 01:55
I cannot get it on my app. I have tried my computer...help I just want the tile on my phone. This is the only tile i really use!
05-14-2018 02:33
05-14-2018 02:33
Hi, @kfarrar, on your app's home page scroll down to the bottom to see "Edit". Click on that, find the step tile and click on the + to add it. You can also touch and hold to drag it to a different position. When you are finished click "done"
05-14-2018 03:10
05-14-2018 03:10
I have tried to edit, but the step tile is not there to add, it seems to have vanished!
05-14-2018 03:27
05-14-2018 03:27
Hi, @kfarrar, that's odd! Try logging out of the app and then logging back in again. If that doesn't work, I would suggest reinstallinng the app.
05-15-2018
10:31
08:52
05-15-2018
10:31
08:52
Hi @kfarrar, welcome to the Forums. Hope you're enjoying some healthy activities!
I noticed that @Julia_G has offered a few suggestions to help resolve your issue. If so, I invite you to mark her post as the solution. Marking posts as solutions is a great way of thanking another community member, while also highlighting their solution; so that it may be discovered more easily by other community member's facing the same questions or issues as you. You can read more about Accepted Solutions.
If this didn't resolve your inquiry, I’ll be more than glad to lend you a hand with that!
Please keep me posted!
