01-31-2017
22:53
05:05
YojanaFitbit
01-31-2017
22:53
05:05
YojanaFitbit
how to reset time and date surge ?
Moderator edit: Clarified subject.
02-02-2017 05:04 - edited 05-16-2017 08:30
Hello @dalestales! Hope you doing great! As @WendyB mentioned you can reset your Fitbit Time Zone on the Fitbit.com Dashboard on the computer. Or if you prefer to use a mobile device, open the Fitbit App > Account > Advance Settings > Time Zone.
Remember that to keep updating your Fitbit Surge time, you need to sync at least once a week. To sync check this steps or you can also sync from a computer.
Have a good one! ![]()
01-31-2017 23:20 - edited 01-31-2017 23:20
For the time go to the dashboard use the gear to choose settings scroll down to time zone and change it there.
It must sync before it takes place
Wendy | CA | Moto G6 Android
05-13-2017 00:33
05-13-2017 00:33
From the fitbit App you need to go to the Advanced settings (not mentioned here) and choose your time zone, then sync and it will update at this point
05-16-2017 08:39 - edited 05-16-2017 08:42
We are so excited to have you in the Forums @Suzy_p! Thanks a million for pointing this out. I've updated the workaround for this issue, thanks to your last post. We believe in team spirit and that we can use our knowledge to help other Fitbitters in distress! ![]()
Have you checked our Discussion board? If you're into Fitbit and fitness you may enjoy other users' comments. Check this board Looking for Fitbit Friends? Find some here! And have some fun interacting with other members!
Hope to see new comments from you! ![]()
Best Answer10-30-2021 12:53
10-30-2021 12:53
Hello I got a Fitbit Surge and I am not able to change the time and date
