03-28-2018 10:41
03-28-2018 10:41
wristband damage what is the fix
Best Answer03-28-2018 14:42
03-28-2018 14:42
It can not be repaired.
I have seen some fixes on Amazon but you need some certain tools.
Wendy | CA | Moto G6 Android
03-28-2018 19:00
03-28-2018 19:00
First choice - warranty replacement if less than 1 yr old.
Second choice - go to Amazon - there are replacements available with instructions and tools for under $15.
Fitbit did not make the band user replacable. The GPS is built into the band, so requires some DIY with the replacement bands from third parties.
There are multiple threads about this exact issue with hundreds of complaints.
