I'm aware that Polar Beat is not listed as a partner/compatible app so I would like to know what are my choices here in order to sync the data coming from my Polar H7 sensor (chest strap) to FitBit's service. The reason is that I use that chest strap to monitor my heart rate during my weight lifting sessions. (although I'm enjoying the FitBit Blaze, there is no way I can avoid using that chest strap for this kind of activity as it's way more accurate)
What are my options here? I know Fitbit supports a lot of different apps/services. All I want to know is an app/service that is compatible with FitBit and that I could use to collect that heart rate information from my chest strap, so I could easily integrate that information into my Blaze.
Does any of those apps that appear listed in FitBit's website (https://www.fitbit.com/ca/partnership) support weight training and a Bluetooth sensor? Or is there any workaround I could use to publish that data from an external service into FitBit's service?
On a side note I tried to use the Strava app to do that for me (as it already works with my chest strap this would be perfect to collect that data) but it looks like that if I set the sport as "Weight Training" in Strava then it won't sync with my FitBit. If I do the same and set the sport as "Walk", "Ride" or "Run" then it will sync properly. Does that proceed? Will FitBit always ignore Strava activities not listed under those 3 categories?
Thank you,
Nicholas
Good to see you around @npufal. The most common option is Strava but activities from Strava are synced over to Fitbit as manually logged activities but will not include GPS or heart rate data from Strava, which essentially is what you need for your chest strap.
I've noticed some posts where users talk about Digifit but according to the information of this API it tracks workouts indoors with fitness sensors or outdoors with GPS. http://www.digifit.com/
| What syncs? |
| Fitbit > Calories > Digifit |
| Fitbit > Sleep > Digifit |
| Digifit > Activities (workouts) > Fitbit |
