08-19-2019
11:51
09:07
SilviaFitbit
08-19-2019
11:51
09:07
SilviaFitbit
hello,
I just bought a 1byone bluetooth that's supposed to sync with the fitbit app. has anyone done this? is there documentation describing what to do?
thank you,
scott
05-27-2020 08:57
05-27-2020 08:57
Yes, you can connect the two. I just did it and now get my 1byOne scale sending my Fitbit my weight!
08-20-2019 09:10
08-20-2019 09:10
A warm welcome to the Community @boulderskies. Thanks for the details mentioned.
You may want to ask directly to 1byone Bluetooth, because Fitbit has an open API, you can learn more about it by checking this post: Third Party Apps - FAQ.
Let me know how it goes. I'll be around if you need further assistance.
05-27-2020 08:57
05-27-2020 08:57
11-14-2021 16:42
11-14-2021 16:42
I keep seeing this same answer but when I do this, I do not get the options in 3. I see no place that I can "select the data you want to sync, then tap "accept" or "agree"
11-14-2021 16:43
11-14-2021 16:43
I keep seeing the same answer but when I do this, I do not get the options in 3. I see no place that I can "select the data you want to sync, then tap "accept" or "agree"
11-06-2022 08:36
11-06-2022 08:36
It didn’t work. 😞
