I cannot add Carrot Rewards as an app as I login through Facebook.
Would like to start collect Scene points. Any help would be appreciated.
Best AnswerHi @lil_bit_mia,
To collect SCENE points with your Fitbit through Carrot Rewards, first download Carrot. After you do so, set up your account and then enable their step tracking feature to start earning for walking. To pair your Fitbit, click Manage Devices and choose Fitbit.
You can find out more on Carrot's FAQ page if you're still having trouble.
I'm not sure how this relates to Fitbit, @lil_bit_mia. Can you please give us more information, such as: Fitbit device model, phone or computer you are syncing to, and exactly what Carrot Rewards are? We're happy to help, if we can.
Best Answer@lil_bit_mia - I admit, you made me curious so I googled Carrot Rewards. First thing I noticed is that this app is for Canadians only. I was not able to tell from your profile if you are Canadian or not so I'm just putting is out there.
Second thing, their Web site does not mention compatability with Fitbit and I did not come up with anything searching for Carrot Rewards in the Fitbit Help pages. This leads me to believe that the two apps will not work together. Maybe someone else will add to this discussion.
Best AnswerDefinitely.compatible with fit bit
Easy set up and sync. Just follow steps when you open the carrot app.
Best AnswerNot so "easy"... Any tips for those of us that are having issues then. I only have a deny option...the allow button is shaded and doesn't work...
@Kkel23wrote:Definitely.compatible with fit bit
Best AnswerMy Allow button is disabled and from reading, it appears that neither Carrot or FitBit wishes to fix.
Carrot, it is your app that is disabling the button.
So basically we cannot switch to a FitBit device? Then why say it works with FitBit when it doesnt?
So my only option is using my phone and Google Fit (which is junk).
Here is what I got from Carrot....so why isn't fitbit getting back to us...
Hi
Thank you for contacting Carrot Support.
We are aware of this issue that is affecting our Android Fitbit users. We are working with Fitbit and hope to have this solved shortly. In the meantime, you can track your steps from your phone using Google Fit and switch it back to Fitbit once this is resolved.
Unfortunately, Fitbit has not provided a timeframe to resolve the issue. Since all your step data tracked through Fitbit is stored on their servers, we are limited in our ability to access it and have to wait for them to fix the problem on their end. In the meantime, you can use Google Fit to track your steps. We apologize for this inconvenience.
Thank you for your patience.
Hello everyone and welcome aboard for the new members of the Fitbit Community.
There are a few things important to mention, as @SunsetRunner said earlier. Carrot Rewards is not officially supported by Fitbit. This doesn't mean it won't work, but the information we have about the functionality of the app in relation to Fitbit is very limited. Nonetheless, there are tons of apps that use our Open API to integrate their service with ours. The best way to tell if an app is compatible with Fitbit is to go to the third party site (or app) and poke around their settings to see if you can connect Fitbit. To learn more about our officially supported third party apps, visit: https://www.fitbit.com/partnership
Regarding the issue you have mentioned that is not possible to sync, there are other users who brought to our attention this as well. We are working our best to have more details or find a viable solution. For more details, please refer to our main topic for this issue and to know our latest updates: Fitbit is not syncing steps to Carrot Rewards App. If you're still experiencing this issue, this is the place to share your concerns.
See you all later and stay tuned for more help.
Hello there @Simmonds2004 and @chantelle.lafla, my apologies for the late response.
Thank you for letting us know is working for you @chantelle.lafla.
@Simmonds2004 you mentioned that Fitbit won't allow to pair the device.Are you referring in specific of the Fitbit app or are you referring that is not possible to connect Carrot rewards? Since it has been a few days, I'm wondering if the issue still persists in your case?
Let me know how it goes. See you around.
