Hi,
I got the Charger HR to monitor my Heart rate while running. I want to sync the info with MapMyRun which i find is the best Fitness app.
Can you tell me how to set this.
When i set it to connect with MapMyFitness app, It looks like it connected Buy All fileds are set to N/A
Thanks
@BadgerHowlin It's nice to see you around! I'm glad to see that you're linking Fitbit with a third-party app. Fitbit will sync distance and calories to MapMyRun however heart rate won't sync to MMR.
This is a great idea and I would love to see it posted in our Ideas Board because those suggestions are viewed directly by our engineers and developers and the best of this is that people can vote for them.
Hope this helps.
02:28
16:28
ErickFitbit
08-17-2015
02:28
16:28
ErickFitbit
This is very disapointing that your HR monitor will not connect to 3rd party applications. Lets face it that is a big issue with loads of people. I have read the Ideas Borad and by the looks of things, if the Engineers and developers even look at the board they dont comment on anything.
I have read loads of posts and not one have I read that its saying,
Yes we are looking into making this work with 3rd party apps.
So I would be under the impression that they dont.
Moderator edit: format
@BadgerHowlin Thanks for those details! As you can see in the ideas, some are implemented or under consideration; the engineers aren't directly commenting there but they are looking at the ideas.
Thank you for your feedback.
