02-23-2021 22:08 - last edited on 02-24-2021 12:47 by LiliyaFitbit
I spent a couple hours trying to do this and I cannot get it to work. I finally got it connected through MyFitnessPal, but according to the instructions I have to log my food through MFP. I already have a food app that I like. Is the only way to connect MapMyRun to FitBit through MFP?
02-24-2021 12:46
02-24-2021 12:46
Welcome to the Fitbit Community, @bawoodworth.
Thanks for the details shared in your post and for already trying to resolve the issue. I understand your concern and recommend confirming the steps from this help article in order to connect your Fitbit account with another app: How do I connect my Fitbit account with another app? Please also check here for more information.
By the way, I've moved your post to Third-Party Integrations board so we can keep our forums organized.
Hope this helps!
Best Answer02-24-2021 13:24
02-24-2021 13:24
EDIT: @LiliyaFitbit I already tried those FAQs. None of them answer this specific question. Also not sure why you made it so I couldn't reply.
02-25-2021
18:40
08:04
02-25-2021
18:40
08:04
Thank you for your reply, @bawoodworth.
I am sorry to hear that you couldn't reply to this thread, the thread is open for replies and you can confirm the steps to post your reply at How do I reply to a message? I appreciate your efforts and the additional details. Since MapMyRun is showing on the list of the Compatible Apps and you've already followed the steps to connect this app to Fitbit directly, I recommend to get in touch with MapMyRun directly.
See you around.
Best Answer02-27-2021 06:29
02-27-2021 06:29
You CANNOT sync Fitbit with mapmyrun as they have removed that feature on the new app. However, Fitbit, in typical style are still advertising this functionality. They should not be doing this. I'm stuck with a tracker (charge 3) that doesn't reliably track, and now another app that does track but wont sync with the Fitbit dashboard. Absolutely useless. I guess I will try Strava, or I might just go out and buy a different tracker that I can actually rely on for a change
02-27-2021 06:31
02-27-2021 06:31
This list is wrong! Check on the mapmyrun website. It is no longer compatible and you need to stop misleading customers and saying they are wrong. It is the list on Fitbit that is wrong!
