07-06-2019
07:52
10:38
LanuzaFitbit
07-06-2019
07:52
10:38
LanuzaFitbit
I’m trying both Noom and WW apps on my iPhone to decide which I like better. I have Noom successfully connected and syncing with my Alta Fitbit. But I can’t seem to get WW to sync. Is it possible to sync to both apps? If so, how do I get WW app to sync?
Best AnswerI'm using both the Noom coach app and the WW app to make a decision on which app I prefer. I've got Noom synched just fine, however, I can't seem to get the WW app to sync with my Fitbit also. Any help would be appreciated -- the more detailed instructions, the better.
Thank you in advance for anyone that can help.
Hello @we2texans.
Let me help you get the Weight Watchers app connected to Fitbit.
You can click here to get some instructions on how to connect WW to your Fitbit. It is definitely possible to get both apps connected to Fitbit at the same time.
Are you getting some sort of error message when you try to connect the two apps? If so, what does it say?
I look forward to your reply. Keep me posted on how it goes.
Best AnswerI just get a blank screen, I have does this over and over and updated all my apps, WW says it is a fit bit problem
