Endomondo not syncing with my Fitbit properly
I am using Endomondo to track where I walk or ride my bike and sometimes the activities that are recorded by Endomondo, that show up in my Fitbit as things that I have done  do NOT show up in active minutes.  Anybody else have this issue?
16 REPLIES 16
@EricLA2 It's great to hear that you're using Fitbit with third-party apps!
You earn "very active minutes" when you wear your Fitbit while doing cardio workouts and high-intensity activities like jogging and running. Note that your active minute count will be lower for activities that are not primarily step-based, such as weight lifting, cycling, and rowing.
Perhaps this article might be helpful let me know if you need further assitance Robot Very Happy
My issue seems to be that when I link Endomondo with Fitbit the very active
minutes I am getting from Endomondo (that record in the exercise log) do
not record as active minutes. I would like to have Endomondo record my
hikes and bikes and have it flow through to Fitbit, but if it won't accept
the minutes as active minutes I can't do that.
Eric Lindstrom
734-730-3563
[email protected]
@EricLA2 Thank you for providing me with more details.
When you go for a walk or a run you shouldn't being logging those activities because your tracker already uploaded your information to the Dashboard.
If you're wearing your tracker when hiking or biking and later log those activities. If the information that you wrote is less active than what your tracker catched, your Very Active Minutes will be taken out from your Dashboard.
Perhaps this article might be interesting.
With the new updates of the Fitbit app - it seems to me that some of the intergrations and the data presentation has been messed up...
My Fitbit used to synch my Endomondo excecises as new excercises for the day - now nothing is added... I know that walks etc. are not synched as it would be double up - but my bike rides, rowing etc. is not transferred anymore ??
@Nesnegroj Hey! Please try unlinking and relinking the accounts. If that doesn't work please contact Endomondo
Silvia Can you help me with my problem?
I running using fitbit.  But after i sync with my endomomdo, the activity in endomon do was show as step counter not my running . How I fix this
@Jan1979 It's great to have you here! Fitbit will sync just steps, distance and sleep to Endomondo. It won't sync the whole activity that you did. When you log an activity in Endomondo those activities will go to Fitbit as activities.
Fitbit > Steps > Endomondo
Fitbit > Distance > Endomondo
Fitbit > Sleep > Endomondo
Endomondo > Activities (workouts) > Fitbit
Thank you So much.
So inorder to see running activity, I need to see in fitbit app only, isn't it?
Is there any other option for me. I think maybe I have to put record to endomondo manually.
@Jan1979 Yes, because Endomondo and Fitbit activity will show in Fitbit. Keep in mind that you don't need to log running or walking activities in your Dashboard because your tracker was made for that.
So i cannot see my fitbit bike ride synced to endomondo? is there anyway?
@MaherAbuZer A warm welcome to the Community! Fitbit won't sync activities to Endomondo that's why you're not seeing the bike ride in Endomondo. Currently, it's not possible to sync the activities. However, you can post this idea in our Ideas Board because those suggestions are viewed directly by our engineers and developers and the best of this is that people can vote for them.
Hope I can continue seeing you around.
many thanks, and i will post to the mentioned blog 🙂
Is there any change to this situation, regarding logging cycle tracks in Endomondo from Fitbit?
Hey there @matstermatt! Currently, Fitbit will sync steps, distance and sleep and Endomondo will sync just activities to Fitbit. You may want to post your idea in our Feature Suggestion board because those ideas are viewed by our engineers and developers, the best of this is that people can vote for them.
My Endomondo and Fitbit are syncing fine however it's done accuratly.
For example i completed 9000 steps the other day yet endomondo recorded it as 3400.
My fitbit is constantly syncing so by the time midnight comes the fitbit app matches the fitbit on arm as near it spot on so how come endomondo is so far out?
Cheers
Welcome to the Community @GreyMack! If you're comparing your Fitbit stats with any other tracker, the results you'll get will be really different because each one has its own algorithm to track data. If you have both apps linked you may want to check this third-party post to learn what's gonna sync between those.
Hope this helps. Let me know how it goes.
