05-23-2021
04:07
09:30
LanuzaFitbit
05-23-2021
04:07
09:30
LanuzaFitbit
Anybody having issues the last 2 days with Strava not being updated from FitBit app?
05-24-2021
04:13
08:34
WilsonFitbit
05-24-2021
04:13
08:34
WilsonFitbit
Hi all, My ionic syncs to my phone but won't sync activities to Strava. They are connected, I've disconnected and reconnected them and switched both on and off. It gives the correct number of steps including what I did in the run but it just won't upload the activity
05-24-2021 04:35
05-24-2021 04:35
Your instructions did not work. I am using GPS and this problem just suddenly occurred two days ago.
05-24-2021 05:13
05-24-2021 05:13
Is anybody else having trouble with Fitbit downloading to Strava. If so how can I fix the problem please? Strava just says downloads from Fitbit are currently delayed
05-24-2021 05:18
05-24-2021 05:18
Can Fitbit Support, oficially comment and confirm it? As we are all who facing this issue, trying to figure out what is going on.
05-24-2021 05:50
05-24-2021 05:50
That's bad news 😕
05-24-2021 05:50
05-24-2021 05:50
I feel your pain.
05-24-2021 06:16
05-24-2021 06:16
Hello,
in the last 2 days i have a problem with the strava app, it wont track my activity and challenges. My strava is connected with the fitbit app and i tried re-installing poth, i tried restarting my phone and my versa fitbit but nothing seems to work. If someone knows how to fix this problem please reply.
Thank you.
05-24-2021 06:17
05-24-2021 06:17
Yes, i have a problem with strava not tracking my activity.
05-24-2021 06:36
05-24-2021 06:36
All:
Looks like it's not a permanent issue, but certainly an issue that's being "looked into".
05-24-2021 06:37
05-24-2021 06:37
All of a sudden Sense recorded data (run bime yoga whatever) stopped showing up on Strava
I have deleted all apps checked setting liked re set up and approved and linked and all.
This is VERY frustrating
05-24-2021 06:52
05-24-2021 06:52
Il m'arrive la même chose depuis le 15 Mai.....
Quelqu'un sait il que faire?
05-24-2021
06:54
08:29
WilsonFitbit
05-24-2021
06:54
08:29
WilsonFitbit
Still nothing can someone help as I track my running with strava
05-24-2021 07:03
05-24-2021 07:03
Mine too, since the 21st....
05-24-2021 07:04
05-24-2021 07:04
Me too.. I have trued to contact them but no response.. Does anyone have idea why?
05-24-2021 07:09
05-24-2021 07:09
I hope it is not permanent, else it is bye Fitbit and hello Garmin. I think like everyone, all of us cant help but be disappointed with Fitbit on this. The best they could do is help to us understand what they are doing to fix this.
05-24-2021 07:15
05-24-2021 07:15
Must be a glitch I'm having the same issue
05-24-2021 07:48
05-24-2021 07:48
I too was told by Fitbit online support that the Strava app is no longer supported. However i have just had a messaged back from Fitbit support on Twitter and they tell me that there was some confusion of information given on my previous Fitbit online support chat.
I have quoted below my official Twitter Fitbit Support responses:
"Got it. We're able to locate your case and apologies for the confusion. The current issue is being investigated by our team. What the agent is referring, is the Strava app on your watch itself. It was already removed from the App Gallery. If you have a Strava app installed in your watch, you can still use it. But if you delete it, you won't be able to install it again. Your Fitbit account is still connected to the Strava account. Once the current issue is resolved, you should still be able to sync your GPS activities to Strava. Keep an eye for the latest updates in order to get the quickest resolution possible. https://status.strava.com/ Have an awesome day!"
Fingers crossed the issue will be resolved soon!
05-24-2021 08:25
05-24-2021 08:25
Hi not just you, strava saying
uploads from Fitbit are currently delayed
Investigating - we are currently investigating this issue
May 23 14.12 pdt
05-24-2021 08:29
05-24-2021 08:29
Hi not just you, strava saying -
May 23 14.12 pdt
05-24-2021 08:30
05-24-2021 08:30
I contacted Fitbit helpdesk via chat for a separate issue and mentioned was having Strava issues. The response was:
"I want you to know that a couple of weeks ago Strava stops been supported with the Fitbit app. Although is possible it works it might cause issues with the app like overwriting information. Therefore I want to share with you all the other apps that are currently supported with the app: https://www.fitbit.com/us/technology/partnership"
At the time of writing I checked the link and Strava was still prominently positioned as a compatible app. I pointed this out and asked if Fitbit/Strava were no longer going to support one another moving forward or whether this was a temporary glitch? The helpdesk replied:
"This issue has been reported as Strava is not longer supported with the Fitbit app. The most probable thing is that an update will make both apps to be compatible again, nonetheless since I haven't that information, I cannot assure that it will (Either way the pressure in our community helps). So if more people join to comment and vote requesting the app again it's more likely the incompatibility becomes temporary."
I mentioned the communications needed to be clearer, helpdesk said:
"Indeed, this issue has been for a couple of weeks now but yesterday we started receiving a huge quantity of user having similar issues. I do appreciate your understanding and feedback, and I'll make sure make it visible for our team."
