07-10-2017 07:37
07-10-2017 07:37
Hey,
I noticed about a week ago my fitbit and myfitnesspal app have just stopped syncing all together.
My food logged in MFP is not being transferred to fitbi and my activity on fitbit is not being put into MFP.
I have disconnected the two several times via the MFP app but it seems to connect again without asking. I have deleted and re-downloaded both apps and logged in and out several times but nothing seems to work!
Can anyone suggest anything I haven't tried?
Thanks!
07-10-2017 08:57
07-10-2017 08:57
Hi, @IRawson! I found that disconnecting from the mfp side doesn't actually do anything. I would suggest disconnecting and reconnecting from the Fitbit side. That worked for me.
MakMak | Community Council
Best Answer07-10-2017 08:57
07-10-2017 08:57
Best Answer04-07-2018 05:45
04-07-2018 05:45
I've searched all over the web and I can't figure out how to do this. I can only connect from the MFP app. What do you mean by disconnecting and reconnecting from the fitbit side. Please explain the steps.
Best Answer04-14-2018 09:24
04-14-2018 09:24
Hello there @majoma, nice to have you in the Fitbit Community as a new member! Are you experiencing troubles to connect MFP with your Fitbit Dashboard?
If you are having troubles to connect MFP and your Fitbit account, this post might give the steps to address this issue and it will help you how to connect your accounts: Fitbit and MFP not syncing!
Hope this helps and let me know how it goes.
