Hi,
Whenever I complete a run with the Fitbit app and it syncs with Runkeeper the timing information is off.
Fitbit time:
Fitbit Time
Runkeeper time:
Runkeeper Time
It is indeed the same run, however the total time for the two apps are different.
The synchronization does not take into account pauses. I did a 3min stretch half way through and I paused the activity on the Fitbit Charge 3.
This has been the case for a very very long time.
Can you please fix this? It seems that you only send start and end times.
Thanks in advance.
KR,
Kristof
It's great to see you around @kristofre. Thanks for the details mentioned and the screenshot shared.
Since, it's exactly the same run it should be the same duration from your exercise. In this case, I would like you to unlink Fitbit and Runkeeper and then continue checking if your activity syncs without taking into consideration the pauses.
Let me know how it goes.
