07-27-2018 10:58 - edited 07-27-2018 16:53
I ran 2 miles yesterday morning 7am with my versa , but it didn't sych to strava app until later afternoon.
Just did another 2 miles in this morning 7:30am using Versa - Run - record activity. Nothing has been sych to Strava yet so far, now is almost 11:00AM.
Please help look into this sych delay issue, i was reading on the other post, they propose to have done revoke permission on both side strave and Fitbit and reconnect back, I just did, but nothing is helping.
07-30-2018 07:41
07-30-2018 07:41
Hello @happykevin! Welcome to the Forums.
Thanks for sharing your experience and for going through those steps.
In this case I'd like to ask if the information synced in the end or not. Since your post is from the 27th I want to know what happened after your post. On that same note, I apologize for the delayed response.
Let me know if you have any further questions.
Best Answer07-30-2018 12:05
07-30-2018 12:05
Hi Lanuza,
Data has never been sync over to strava automatically afterward.
I was reading on the other post, their solution to do this manually.
So,
What i did was to export the TCX file from the fitbit side and manually import into the strava. It worked, but this takes time to do it.
I'll try to run again tomorrow morning using the Fitbit versa again using "expercise-Run". Let see if the data can sync to Strava automatic or not. I'll update here later with the result.
Best Answer07-31-2018 16:31
07-31-2018 16:31
I'm experiencing the same issues as @happykevin.
I've removed and reinstalled all authorisations from both fitbit and strava, but still strava activities are not being sent through to fitbit. I am having to manually add them.
Has been going on for about a week now, none have auto-updated in this time, even delayed.
Thanks
Patrick
08-01-2018 09:33
08-01-2018 09:33
A quick update this morning:
I just done another 2 miles running this morning using Versa - Run to record.
I've done the running around 8:05 am today, data automatically synched to Strava around 8:20 am, a huge improvement compared to the last 2 activities recorded.
08-01-2018 18:26
08-01-2018 18:26
Uploaded a new ride to Strava 9am this morning.
It's now 1130am and still not on Fitbit
Best Answer08-02-2018 09:38
08-02-2018 09:38
Hey @happykevin and @flash_222.
@happykevin thanks for sharing that update.
@flash_222 Thanks for letting me know. I'll be sharing this with the rest of the team. If I receive some updates I'll be sure to let you know.
08-09-2018 01:10
08-09-2018 01:10
Hi,
i have just this week started to have issues with Strava bike rides not synchronising with my Fitbit app. The rides successfully track and save in Strava and until Monday were consistently syncing to Fitbit. Fitbit would usually have an autotradked “outdoor bike” session but this would be deleted by the app over time. The last ride that correctly synced was Tuesday morning, and my last 3 rides (tues pm, wed am, wed pm) have not synced to Fitbit. Nothing I am aware of has changed in that time, and as I write this I have updated to the new android version. Having installed that, the 3 missing sessions are still missing.
I also have regular, but inconsistent issues with my Fitbit app not successfully saving manually tracked walks - I will end the exercise and be presented with a white screen where a map should be. Sometimes the map appears, often it doesn’t. Last night I tracked a walk back from an exercise class and all it’s saved is an auto saved exercise, as if I never set off the tracking in the first place. This issue has gone on for a year now without resolution. Admittedly it’s nothing to do with Strava integration but it’s another issue with the app in this instance.
Any advice you you can give will be appreciated. I’m running an Alta HR through a Samsung Galaxy S6, Fitbit v.2.76. Strava is on the latest version.
08-10-2018 11:18
08-10-2018 11:18
Hello @CircusofJoJo.
There was an issue with slow uploads from Strava that was resolved on Wednesday. I'd recommend that you try to disconnect the two apps and then connect them again. That should help so that this doesn't happen from this point forward.
As for the walks tracked by the app, our team is aware of this issue. While we do not have any news on the matter we'll be sure to let everyone know the moment we have some news on the matter.
Best Answer08-10-2018 12:36
08-10-2018 12:36
08-12-2018 12:16
08-12-2018 12:16
Thanks for letting me know that it worked.
It is important to note that if Strava starts working, it will not retroactively sync activities in the past to your account. I will work from that point on, but not with walks that were already on your Fitbit account before the latest connection. That is probably what is going.
Having said that you could export your GPS data and then manually upload it to Strava to make sure that those activities are also showing up in there.
Feel free to let me know if you have any further questions.
Best Answer08-12-2018 15:10 - edited 08-13-2018 05:46
(Edit: sorry, I noticed the screenshots didn't add in. Visualise a list of 3 "outdoor bike", 1 autotracked walk, and 1 walk with a GPS map, and one image of a blank screen where all the exercise details should be)
Hi Lazuna,
I disconnected and reconnected the apps again this evening prior to some
cycling. I have seen no change in the issue- I tracked the rides in Strava
and they worked just fine in the app, but in Fitbit I have 3 outdoor bike
sessions where the tracked cycling should have transferred across. I think
one ride will automatically delete as I have two showing with a 19:30
start, and one of them is blank when I click on it. Here is what I
currently have:
The second of three rides is just a blank page; from experience these
self-delete:
In short, walks will synchronise from fitbit to Strava when they track
successfully and don't lose the GPS data (this happens 50% of the time,
most recent example of a fail is the 63 min walk in the screenshot above),
but cycling will not synchronise from Strava to fitbit. Im glad the walks
are synchronizing again (when tracking works), but it looks like the fix
hasn't worked just yet.
08-13-2018 00:28
08-13-2018 00:28
I also disconnected / reconnected everything from both apps, and a ride i did on Sunday morning on Strava didn't sync across to fitbit.
Getting tired of having to manually add everything!!
thanks
Patrick
08-14-2018 06:08
08-14-2018 06:08
Hello @flash_222 and @CircusofJoJo.
Thanks for sharing all of that.
In this case I'd try getting in touch with Strava directly to check if something is going on on their end since it is mostly the tracking done on Strava that is not crossing over.
Please do keep me posted on how it goes or if you have any further questions.
08-15-2018 15:44
08-16-2018 08:16
08-16-2018 08:16
Hey @flash_222.
You're very welcome. Please keep me posted on how it goes, I'd like to keep an eye on this situation.
Also, maybe you could visit one of our Discussion boards if you have the time. Lots of different topics to talk about with other users.
If there are any further questions feel free to let me know.
08-17-2018 09:42 - edited 08-17-2018 09:43
quick update:
Just did 2 miles running this morning around 8:40, it sych to strava around 9:10. so It's getting better now.
08-20-2018 00:50
08-20-2018 00:50
Hi Lanuza,
Just to update you, the synchronisation of cycling from Strava to Fitbit is still not working at all. I submitted a ticket with Strava last week to see what they will do - will keep you all posted in this thread. The Fitbit walks synchronise to Strava eventually, but do often take 30+ mins - though I'm not bothered about the delay since it is at least working!
Thanks.
08-20-2018 08:12
08-20-2018 08:12
Hello @happykevin and @CircusofJoJo.
Thanks for the update both of you.
@happykevin Glad to read that it is getting better now.
@CircusofJoJo Definitely interested in reading what they tell you. Be sure to keep us all posted.
If there are any further questions, please let me know.
08-23-2018 07:28
08-23-2018 07:28
I'm having the same problem. Runs uploaded to Strava do not sync over to Fitbit at all for me. It's very frustrating. I've disconnected and reconnected through both Strava and Fitbit but it simply doesn't work.
