06-15-2016 11:10
06-15-2016 11:10
Best Answer06-27-2016 14:49
06-27-2016 14:49
@NatalieJean thanks for joining us! I'll do m y best to answer your inquiries about your calories burned and MFP. First, make sure to do the following to correct the discrepancies you are currently showing:
1. Log in to your Fitbit dashboard and click Log > Activities.
2. Verify that the activity was not logged twice.
3. Go to your Account Settings (found under your profile picture), and scroll down to Preferences. Disable Calorie Estimation.
4. Turn off Personalized Meal Plans in your Fitbit account.
5. Wear your Fitbit for all activities.
6. Log your cardio exercise on the MyFitnessPal site.
Now, the tile that lets you know is the tile for your Food Plan and looks something like this:
And this tile changes as you log your food and it varies depending on the intensity of your Food Plan. Your Food Plan tells what the deficit of calories you should have daily:
This view is a real-time calculation of your calorie deficit and shows whether you're in the goal zone set by your Food Plan. Your plan's deficit is pro-rated over the entire day. For more info about food plans, click right here. Hope this helps. Keep me posted, I'll be around!
Did you receive the answer you were looking for? Mark the post as an accepted solution! 🙂
06-27-2016 14:49
06-27-2016 14:49
