12-30-2018 13:08
12-30-2018 13:08
I have everything turned on and loaded. I see that fit bit tells me there are no syncs waiting. And mapmyrun sees my Fitbit. But mapmyrun is not updating my run I did today.
Best Answer01-01-2019 04:33
01-01-2019 04:33
Welcome to the Forums @Luciousclay.
Let me help you get your Fitbit and MapMyRun app to sync.
Please do keep in mind that only the step history will be synced over to MapMyRun, nothing will be synced from MapMyRun to Fitbit. Having said that, I'd recommend that you try to disconnect the two apps and then connect them once again. That should do the trick.
Let me know if you have any further questions.
01-01-2019 04:33
Best Answer04-03-2020 03:15
04-03-2020 03:15
Th8s feature does not work well
