03-30-2017 05:14
03-30-2017 05:14
MyFitnessPal and Fitbit aren't syncing with each other. Any ideas how I can resolve this?
03-30-2017 20:56
03-30-2017 20:56
I have this problem too. The app is not showing as connected
Best Answer03-30-2017 21:05
03-30-2017 21:05
I am also having this same issue.
Best Answer03-30-2017 22:56
03-30-2017 22:56
Best Answer03-31-2017 00:34
03-31-2017 00:34
Mine's not syncing either, I'm assuming it's the update which installed yesterday?
Best Answer03-31-2017 09:18
03-31-2017 09:18
Mine didn't sync yesterday and doesn't seem to be doing so today... anyone have a resolution yet?
Best Answer03-31-2017 09:25
03-31-2017 09:25
I diconnected the apps and re linked them but I still can not see my daily activity on my fitness pal.
Best Answer03-31-2017 09:36
03-31-2017 09:36
Take a look at the information post on Myfitnesspal you'll notice that Myfitnesspal does not pull the calories from Fitbit.
As for how third party integrations and how they work, please see tht Third party FAQ
You may have noticed I moved your third party question out of the Hardware section, to give it a more relevant audience.
Best Answer03-31-2017 09:43
03-31-2017 09:43
My Charge 2 is not syncing with MFP. I've checked both apps to make sure permissions were correct and they are. My steps and exercise are not showing up on MFP. What am I missing?
Best Answer03-31-2017 10:09
03-31-2017 10:09
@mmcbane72 if both apps say they are connected, but your Fitbit account and MFP are still not playing nice I would through Fitbit revoke MFP following this post then wait at least fifteen minutes are until the next sync of the tracker. Now through MFP set the line no up again.
If this still doesn't seem to work, please reach out to MFP since they are responsible for the connection.
03-31-2017 10:37
03-31-2017 10:37
Fitbit not syncing with my fitness pal
Best Answer03-31-2017 17:53
03-31-2017 17:53
I think I have solved this one. I got mine to work by making sure all options for sharing were checked. I had originally opted out of the friends sharing.
Unlink everything and start from scratch to pair the apps, making sure all options for sharing are selected.
Best Answer04-01-2017 08:34
04-01-2017 08:34
That worked. Thank you!
