01-05-2022 05:31
01-05-2022 05:31
My fitbit GPS runs aren't loading to Strave.
I've tried Disconnecting and re-connection through Strava but this doesn't work.
The Strava app doesn't come up in my fitbit settings under 3rd party apps. But Strava says they're connected.
Any ideas?
01-05-2022 12:02
01-05-2022 12:02
Welcome to the Fitbit Community, @Hayley93.
I'm sorry to hear about the difficulties you experienced. Thank you for trying to get them resolved before contacting us.
Please check if Strava shows up in the list of third party apps connected to your Fitbit account here. If it's not there, please connect your two accounts by following these instructions.
If you continue having difficulties, please try to revoke access from your Strava account and try once again to connect them by following the instructions shared above.
Hope this helps.
01-09-2022 00:52
01-09-2022 00:52
Thank you. Should the runs I track on my Fitbit automatically be showing to Strava? Because they still aren’t. Thanks
01-09-2022 17:09 - edited 01-09-2022 17:12
Thanks for your response, @Hayley93.
Some of your activities should automatically show up to Strava, however the following types of activities won't sync to Strava:
For more information about what data is transferred between Fitbit and Strava, please visit this post.
See you around.
02-05-2022 01:50
02-05-2022 01:50
Hey I've been having the same issue for about 2 weeks. I've got a fitbt charge 3. I've revoked access and connected it again though still data won't load.
Any ideas?
02-06-2022 11:23
02-06-2022 11:23
Welcome to the Fitbit Community, @aashay.
To have a better understanding of your issue, please provide the following information:
- Are you registering your activities with GPS?
- Do you see the map on your Fitbit account?
- What type of activities do you usually perform?
- Were you able to sync those activities to Strava before?
I'll be waiting for your response.
06-11-2022 00:02
06-11-2022 00:02
I have a Versa 2 and my 3 weekly runs have been happily syncing with Strava until the end of May. I would like some help on this too please.
Answers to above questions
GPS - yes
Activities - running
Was able to sync before
re mapping - not sure where to find this - please kindly advise
06-11-2022 14:11
06-11-2022 14:11
@llassahred if you open the activity in your Fitbit app log, do you see the map with the route of your run. If not, then it means the GPS never connected (despite being enabled) and such run won't sync. To be more precise, it's not that the GPS-only activities can be sync but the GPS must connect to provide any data.
06-13-2022 12:59
06-13-2022 12:59
Thanks for the clarification on that t.parker - it's much appreciated. I hadn't noticed that there was no map on the unsynced runs (and also on some hikes I did recently too, which tbf were probably out of signal as they were remote and high).
Clearly the connection to GPS didn't happen, in fact I reset the feature yesterday and then recorded my run this morning on my fitbit and on strava and it's recorded the run twice!
I'll keep an eye on that though - really appreciate the answer to my puzzle!
12-27-2022 06:36
12-27-2022 06:36
Hi, I have been having the same problem. All my previous runs have uploaded to Strava and I've been doing the same routes. I have tried disconnecting and reconnecting several times with no luck. According to Strava, it is still linked to Fitbit app. The runs on Fitbit are still coming up with the map but still not syncing to Strava.
12-27-2022 06:56
12-27-2022 06:56
Hi,
I've given up - I spent 3 billion hours on a Fitbit helpline to be told they don't have a link with Strava anymore. My husband's still did sync, so I asked why that was to be told his would stop soon too. His is sporadic.
Just using my phone for runs now and will ditch Fitbit for good and look at Garmin at some point.
Good luck!
12-27-2022 15:30
12-27-2022 15:30
Thank you! Such a shame!! It was such a good feature
12-30-2022 12:53
12-30-2022 12:53
Thank you for this info! I've also spent a billion hours disconnecting and reconnecting strava and still does not work. I can't believe that Fitbit would discontinue this incredibly useful connection, and I'm furious they would keep that fact a secret from all of us. The forums are full of people who are still being told to disconnect and reconnect. What a terrible way to treat your customers.
01-02-2023
08:36
10:01
EstuardoFitbit
01-02-2023
08:36
10:01
EstuardoFitbit
Hello! I’m having the same issue!
my runs stopped syncing since the 7th of November.
the runs show up with the map, gps etc on the fitbit app. I have tried disallowing access from both sides, turning my phone off and off, dis and reconnecting my Fitbit etc etc.
I would love your advice. I’m using the Fitbit charge 2 together with iPhone SE
And yes, they were syncing fine before and my activity is running.
Same here! Did you find a solution?
Moderator Edit: Merge replies
01-02-2023 09:36
01-02-2023 09:36
I have not found a solution, and I don't think there is one. Apparently Fitbit decided not to let us sync to Strava anymore. 😞
01-02-2023 09:44
01-02-2023 09:44
Hi! That sucks! So weird!I love using strava for the social element... I wonder why they discontinued the sync... Thanks for your reply though!
01-02-2023 09:52
01-02-2023 09:52
@Amarguerite I don't believe they discontinue it. It still worka for me with no issues. Mind thay customer support will start making things up when they go off-script. Simply, for some people Strava support is apparently broken but probably not enough people to care to investigate it.
01-02-2023 09:56
01-02-2023 09:56
Oh thanks for your reply! I will look into it some more then. It's so silly... why would they discontinue it when it was a great feature?!
01-02-2023 10:11
01-02-2023 10:11
Hi t.parker - would you mind telling us exactly what you do to get Fitbit to sync your activities to Strava? It stopped working for so many of us, and one commenter says they were told by customer support that Fitbit is going to eventually discontinue the feature for everyone... But it's hard to know what is happening since they don't seem to comment here.
01-02-2023 10:23 - edited 01-02-2023 10:25
@HannahWincester nothing. I linked it on May 30 last year and it has just worked since. I just spoke with customer support but chat assigned me some dummy who probably didn't know where he was. He was mixing up two things - Strava watch app (which has been discontinued long time ago) and Strava link. I believe the rumor about discontinuing Strava support comes from that side. Customer support person thought about the Strava watch app which once was supported and has been discontinued.
Edit: I'm going to deactivate link with Strava and reconnect again. I will let you know what the outcome is (if I lost Strava sync completely or it still works).
