04-03-2014
16:54
08:55
AngelaMa
04-03-2014
16:54
08:55
AngelaMa
Any using the fitbit to get points at Walgreens. I am having trouble trying to sync with the Walgreens dashboard.
Help please?
09-25-2015
14:53
07:27
09-25-2015
14:53
07:27
@mcdough Can you try going to the Online Dashboard and click on "settings" (under the gear icon on the top right corner). On the left column, search for "Applications". If you see Walgreens; that is the reason why its not letting you. If that's the case, revoke the access to it and link it again. I know you stated that you already did that, but try it again as it might be a server problem.
Let me know how it goes.
Best AnswerThat link only goes to a page full of apps. Where is the article/directions on how to link FitBit to Walgreens?
thanks
07:11
07:28
05-01-2016
07:11
07:28
@mcmunnd Welcome to the Fitbit Community! Follow the next steps to link the Walgreens app with the Fitbit app:
Hope this helps. Let me know how it goes! ![]()
I keep having a connection error when trying to sync fitbit with my walgreens app. Every time I try reconnecting I keeps having issues.
07:14
07:26
05-22-2017
07:14
07:26
@Gabby4h Welcome to the Fitbit family! Are you getting any error messages?
I recommend trying the following:
This should help you out!
Try it out and let me know how it goes!
I looked at your "article" link and just see a list of compatible apps and nothing of any help?!
Best AnswerI have downloaded the Walgreens app on my phone via my FitBit's compatible apps page and went through the permissions in order to sync the app to my Fitbit, but whatever I do, it isn't syncing despite the permissions. I decided to Google how to sync the app and got this:
"How to link fitbit to Walgreens app?
A: Log in to Walgreens.com/healthychoices and follow the steps below: Log in to Walgreens.com/healthychoices and follow the steps below: 1. On the Balance Rewards for healthy choices dashboard, click on the WebMD tab, then click the Manage My Goals button to view available goals and set one or more goals."
Well, I tried this and seemed to have a bait and switch pulled on me. I was forced to make a Walgreens pharmacy account instead?! I am VERY unhappy with the run around I seem to be having with this app!
Well, I decided to try the pharmacy account stuff and now I have to wait for however long they decide to check my information before I can even sync Fitbit... what a joke!
08:10
07:27
06-26-2017
08:10
07:27
@MillerPennzoil2 Thanks for joining the Fitbit family! On the article you can click on "Walgreens Balance" and then on "Learn More" and you will get to this page where you can link them.
The easier way to get the steps on how to link them is by checking this post. Please follow those steps to link Walgreens with Fitbit.
Also, if you already have them linked but not connecting; the best thing to do in this case is to follow the workaround on this post. That is the best way to get Walgreens and Fitbit to sync if you are experiencing any issues with that.
Keep me posted!
I went through FitBit's compatible apps page and that's how I got started. It tells me that I am synced, but I still have to manually enter my activities. Also, I checked that page and I do NOT see my Fitbit. I have a Fitbit Charge 2.
13:44
07:26
06-27-2017
13:44
07:26
@MillerPennzoil2 Thanks for your reply! Please follow these steps to connect both apps:
Try that out and let me know how it goes!
Do you have any idea why it is compatible with all Fitbitbits except for the Fitbit Charge 2?
07:04
07:26
07-06-2017
07:04
07:26
@utalice I hope you're doing well! Please check the steps I left on this post to get them linked together. That should certainly help you out!
@AmandaDavis Welcome to the Fitbit family! It should be compatible with any Fitbit tracker, I believe. Where did you find that information?
Keep me posted! ![]()
Best AnswerWHAT instruction??!!
This seems to happen every time they update the Walgreens app. I contacted Walgreens and they hung up on m .
Best AnswerHelp link provided above is no help because it just sends you back to a place for downloading the Walgreen App! I’ve been using Walgreen’s App on my iPhone 6 for 8 years. I’ve tried numerous times to get the Walgreen’s App to connect with my Fitbit account to no avail. Walgreen’s sends me to Fitbit login screen but the “activity” indicator grinds away and login page is ghosted. It stays like this until I close the Walgreen’s App. It’s obvious that Walgreen’s App cannot successfully connect to Fitbit’s website. Walgreen’s, of course, provides no advice—both companies just point at each other. It would help if both companies would remove their claims of inter-connectivity.
Today is February 6, 2020, my father's birthday. He would be 109 if he hadn't died at age 94. So would Ronald Reagan. I digress... After a half-hour of frustrating "Chatting" with Walgreens, I was told they don't track info from my Fitbit Versa. They now use "Challenges" and every week I have to check in and record my weekly progress before 11:59 pm Sunday. So much for automated and Walgreens Rewards. I don't need another deadline.
