03-02-2017 10:41
03-02-2017 10:41
Please make fitbit sync with the Livestrong app. I have used Livestrong for 6 years. It is very frustrating that I cannot get my activities to track on Livestrong. Can you fix that?
03-02-2017 12:02 - edited 08-08-2019 22:16
Hello @jpc02043, your question is beyond the scope of the comunity of Fitbit users that post here to "fix".
Fitbit does not force any third party to connect, and is unable to do this. Fitbit has an open API which allows third parties to access a Fitbit users data. My suggestion is to approach Livestrong, maybe if enough users want this feature they will add it. This needs to be done by them, not Fitbit.
 Best Answer03-02-2017 12:02 - edited 08-08-2019 22:16
 Best Answer08-08-2019 15:36
08-08-2019 15:36
I don’t like that it is marked as “solved” when in fact it is not. Just because the developers at FitBit don’t want to build in connectivity doesn’t mean that the problem is “solved.” It means that they are lazy.
08-08-2019 22:12 - edited 08-08-2019 22:15
Well @AaronBrand19 as mentioned in the solution. Fitbit does not build a connection to third party apps, but invites them to use the Fitbit API and build let's them build the connection.
This really is very easy for a third party like Livestrong to do and their are apps that Fitbit doesn't even know that can have access to a users data.
In short this link up will need to be done by Livestrong, Fitbit has already provided the tools.
Since this post is about third party apps and not about a Charge 2 hardware problem. I'll move the post to app connection board but really since it is a suggestion it should be in the feature suggestion board.
08-09-2019 07:21
08-09-2019 07:21
 Best Answer08-09-2019 10:05
                              08-09-2019 10:05
Some third parties don't take any data from Fitbit but only send data.
Considering that the request is to have Fitbit data sent to LiveStrong, maybe this is the wrong thread.
For the above request to happen, Livestrong would need to set it up.
However if Fitbit set it up, they could, and probably would send data to them anyway.
This is what happens wig Strava, since what Strava wants is not availible through the API.
