@chrisnow Welcome to the Community. I've moved your post to this thread.
@Pthole8 A warm welcome to the Community! It looks like you can upload your weight and body fat to Fitbit as @chrisnow mentioned. However, just those stats will sync to Fitbit. I would contact Yunmai scale directly for more information.
Hope this helps!
Hi everyone and you are correct @rjlaustx. As you mentioned before If you already enable the integration within Yunmai, you need to go to "me" under Yunmai app, from here select "user settings. Slide fitbit to On. To connect Fitbit. It will ask to agree to finished.
Now if you step on the scale you can weight in the normal way. Following steps: open Yunmai, step on scale, wait and if yunmai has finished the data will be automatically sent to Fitbit.
I found this piece of information from the FAQ on Yunmai page: Fitbit will sync latest data only if you fully exit the app (for iPhone, please double click start button and swipe with finger up) then reopen it.
If this is not working the only recommendation I can give is to revoke the access and re-link again Yunmai with Fitbit. If the issue persist since this integration was not built by us, I recommend to approach to Yunmai customer support.
Let me know how it goes, I'll be around for any additional question.
Hi there @Sud, thank you for sharing with us this is working for you. I'm sure other users who might be experiencing this with Yunmai will find useful your recommendations.
See you around and keep participating in our Fitbit Community.
Got an Yunmai Premium scale for Xmas and was having the same problems has everyone else...no communication with the Fitbit app, etc. Decided to delete the Yunami app and try another App and went with the second choice in the Apple App store, MyFit Tracker (also by Yunami). It's basically the same app, but when you allow Fitbit in the user setting, you get a check box for weight. Make sure it's checked and then just follow the rest of the regular instruction as listed in the set up guide. Both my wife and I now get reading in our Fitbit app from the scale. It works!!! hope this helps.
Can you tell us what version of yunmai? I want to make sure it will work before I buy the scale. I planned to buy yunmai mini
Best AnswerI have the Yunmai Color Scale, but anything they advertise as supporting IOS will work (on an iPhone, not an iPad.)
Best AnswerYes, it works and is "touchy." Mine worked great for a long time, then suddenly stopped syncing with FitBit (although Apple Heath worked.) I'm not 100% sure how I fixed it, the symptom was when you turned OFF FitBit sync, it ignored you and put it right back. I rebooted the iPhone, made sure Apple Health WAS running and FitBit app WASN'T, THEN it let me turn off FitBit Sync. After I terminated the YunMai app, THEN it let me re-enable FitBit and re-enter the fitbit account info, and it all syncs fine again.
It's a hassle, but totally worth it.
Best AnswerThank you for all the replies. the thing is I only have Ipad as Ios. I use android phone. (one plus 5t) anyone here has any experience?
Anyway, I already ordered Yunmai Mini. Hope it will work.
last time I order yunmai mini 2 (yunmai balace) but unfortunately it came with Chinese version and doesnt work with international app. it forced me download chinese application instead. so be aware for this
MrForm
Best AnswerYou'll have to use your Android phone. I have no experience in that, except a friend a bought a Yunmail scale for says it worked great on his Moto Z Android phone.
Hello everyone!
@MrForm In that case I'd say that the very best way to get full details on the matter is to get in touch with Yunmai directly. They should be able to orientate you in regards to how their ecosystem works.
If you have any questions, maybe you could check our Discussion boards out. Lots of different topics to talk about!
Let me know if you have any further questions.
Best AnswerTypical Fitbit "Moderator" -- AKA useless or uninformed. FitBit should aggressively support it's ecosystem, but they don't. They leave users to flounder.
Best AnswerThis worked!! Thanks
