10-01-2019
13:21
05:56
AlejandraFitbit
10-01-2019
13:21
05:56
AlejandraFitbit
I've read and followed all directions and advice from one forum or Q&A after another. Nothing corrects the issues with the device syncing to MyFitnessPal. Ever since I bought the Charge 3, it hasn't synced. My older Fitbit, can't recall the model, always synced and was always updated.
What's the deal? Why can't this be corrected? Why is it so dang difficult to get this device to do what it is supposed to do?
10-02-2019 05:59
10-02-2019 05:59
Welcome to the Community, @Dollene2040.
I appreciate all the efforts in trying to fix this syncing issue. Also, I wanted to let you know that I have moved your post from the Charge 3 board to the Third-Party Integrations board, since I think that here you will be able to see more related topics about this problem.
Now, if your Fitbit account isn't syncing with MyFitnessPal, I recommend taking a look at this post and make sure you have followed the instructions provided there. If your tracker is syncing properly with your Fitbit account, I recommend contacting MyFitnessPal support.
Let me know if you need anything else. 🙂
10-14-2019 09:13
10-14-2019 09:13
My fitbit Ionic is not registering my exercise steps on Myfitnesspal after ios 13. Normally after it syncs it shows in myfitnesspal but this day I got 40 active minutes with over 5,000 steps 2.24 miles and 464 calories and none of that registered under EXERCISE in Myfitnesspal. I followed the updated 10/9/19 notification on this page and nothing changed.
10-20-2019 19:09
10-20-2019 19:09
Hi @Sdeeb1950. Welcome on board and I'm sorry for the delayed response.
I've moved your post to this new thread so you can receive more related responses about the issues experiencing with your Ionic not syncing on MyFitnessPal.
I appreciate the information that you've provided, as well the steps tried prior posting. I'd recommend to try the following steps, that way we can get your Fitbit account to communicate with MyFitnessPal:
Once that is done, please reconnect MyFitnessPal one more time with Fitbit:
If the issue persists, my best recommendation is to get in touch with MyFitnessPal. This way they can take a deeper look and give you a hand.
Keep me posted.
10-23-2019 11:34
10-23-2019 11:34
Hi there,
if you still have issues with MyFitness Pal, maybe you could try this solution (Fitbit sync to Endomondo and then Endomondo to MyFitness Pal):
https://community.fitbit.com/t5/Third-Party-Integrations/MapMyRun-is-not-syncing/m-p/3853380/highlig...
